if the slipper loosens up, the pad glazes and the nut and spring lose tension causing the need for all parts to need replacing.....
Right, I'll tighten it down!!
I've got to ask...
What happens if you don't lock it down??
So when you say run it locked down, you are referring to running the nut all the way down tight?glued behind the spur is a pad and pressure plate system which absorbs shocks to the drive system, it is adjusted by the nut and spring in the center of the spur gear, most run it locked down to prevent the spur and pad being damaged by excessive slipping...My manual has a complete breakdown of the system on page 37
