Breakin in new Picco Outlaw .26
instigator10
Illinois
This Picco I have,the rotostart will turn it over with thw plug out but when I put the plug in it the thing barely turns over.Any suggestions.
just loosen the plug a little bit to ease compression, get it started, then tighten the plug
The one way bearing seems to crack pretty easy on them, I have had three of these engines. It is hard to tell if it starts to hydro-lock with the roto but it doesn't take alot to split the owb, that may be the issue with yours. The best way around this problem is to run a pull start, then you can feel when there are issues and do something about it before the owb let's go.
