Best Starter Option
jester296
Ohio
I was just curious which starter was better the roto-start system, a drill, or a pull start. i had a roto-start but hated charging the battery so i switched to pull start and have recently noticed people using drills as a starter.
imo, pull start all the way. drill would work if you wanna be haulin a drill around with you all the time. besides, if your truck doesnt start after a couple pulls then youve got another problem to address (fuel, g-plug, etc) 😛eace:
I'm with frddy on this one pull start all the way
I am a huge fan of the pull-start.....
I did use a drill when I had the roto-start backplate but if you go that route you need to know when it gets flooded so you don't try to keep starting it when it is flooded.
