What kind of Spur Gears and Clutch Bells do you guys use? I'm not too concerned about gear ratio's, but more about what brand of gears you guys are using. HPI, Hot Racing, Integy, Robinson Racing. I've been burning up spur gears lately and I have a feeling things are getting too hot since the teeth melt/strip within 5-10 minutes of on-road operation. I have yet to take off the CB and check my clutches. Things that you probably need to know in order to help me:
-2 year old Stock Savage 25, no modifications, only about 1-2 gallons of fuel ran thru it.
-Stock 49/15 Spur/CB gearing, have tried 52T Spur-no change.
-Happens under any conditions, even on warmup runs up/down my street.
-Tried multiple gear meshes, from paper thin to slightly sloppy, only change is where on the spur gear teeth gets melted, closer to top of tooth or closer to center of the gear.
-On my 8th Spur gear.
-Have tried different Slipper Clutch settings-no change.
-Engine plate or anything like that is not bent/cracked.
-Engine mounting bolts are locktited down.
-Had this problem before which made me hide the truck for a year.
-Engine was tuned to 250 degree range last time I had it running.
Any thoughts are welcome. I have a feeling I should find out why this is happening, rather than getting heavier duty gears, but it may be necessary...
