Carbon pads too?
Cheers, i have found, if you tap the hole into the plastic part, remove it and then threadlock it and put it back in it tends to last a lot longer.Yes I confirm. They wont hold stuff in stock, but can be ordered on request.
In my opinion the easiest way is dual fibre brakes. Cheap, last a season and for new season just new set. The problem usually is gearbox housing and the screws coming loose. In the innovative-rc brake kit the screws are not self tappering and are for metal so screwing them in plastic I'm not sure how long they can hold if your going to bash it.
Linkage mod, high torque servo+ dual fibre disks you shouldnt have any problems.
