Bad Plugs????
puckamahow racing
Anyone know why I might be burning 2 glow plugs out in a matter of minutes All started out good couple of warm up runs then go to put the top on and it stalled wouldn't start checked the plug and found it to be broken half way up the coil....changed for a new one same problem....the plugs in question are o'donnell,anyone else ever had an issue with these plugs?thanks for the help in advance...Leon.
Sounds like fuel. But that's stating with no other evidence.
First thing I'd do is run a colder plug. Depending on the temperature outside, it might just be toooo hot. If a plug is burning up, it's gonna crack, then break completely.
Try a colder plug, also, name off some of the things it's doing.
Is it running hot?
Hard to start?
What fuel?
Clean air filter?
Also, try clean the motor fully. Run some after run oil through it. Sometimes dirt can get in there and cause problems like that. If so, GET IT OUT. Dirt can kill your engine quicker then anything. 🙂
Buring glow plus out in a matter of min .. Sounds to me like you have METAL in your engine .. pull the head off and look at top of piston .. LMK what you find
thanks for the tips guys will check a few things out then get back to ya
it started fine and idled great took a few laps around the parking lot when i brought it in to put the top on it stalled tryed to restart no go checked the plug and seen it was broken replaced it with new and same problem temp was good and it was 16 above zero but will checkthings out and get back to you.thanks again guys.:jamout:
