6v hump pack connections??
xxJaRxx
Ive just bought a 6v hump pack and the connection at the end fits straight into the receiver, which then of course by-passes the switch and is constantly on. How do i get it to go through the switch so i can turn it on and off?
Thanks
what kind of harness do you have? there should be at least two connections coming from the on/off switch. One connects to your hump and the other to your receiver. If its not this way post a pic of what you have so we take a look and give you a better answer
umm everything is totally standard and yes ive got 2 connections coming off the switch, the one which plugs into the receiver is the same as the one coming off the hump. Ive just seen a post lower down which asks the same question (sorry) and the reply there is to cut the 3 pin connection from the hump to fit the 2 pin connection to the switch, but it looks a bit dodgy to me..
