300mm body?
k0m0d067
when they quote 300mm, are they measuring width? or length?? someone said a 200mm body would almost fit a savage...so would a 300mm fit on my FastLane extended beast??
300mm between front and rear axles? so does anyone know off the top of their head if 300mm will fit the extended FLM tvps?
nvm...just did the math, and it's slightly less than 12 inches...
thats an RS4 shell. correct me if I'm wrong but the RS 4 is HPI's touring car??
sorry bud i am being a retard. the 200/300/190mm is wheelbase, so yours at 12 inches is 300mm. it should fit and be to scale, dunno bout roll bar, mill head etc, and yes the rs4 is a touring car, damn fun
no, I'M the one being a tard...by wheelbase you're reffering to width? or length? doesn't matter about the body anyway..I went and drank beer and worked on my racer, instead of bidding...LOL
it will fit as if you are making the car look like a real car. ie it will almost go all the way to the end of the tyres. we had a doge viper shell which we tried. the wheels bind all the time with this size of shell
I was planning on putting it on my FLM extended/lcg tvp'd Savage-behemoth...so I doubt it would bind...LOL
no its binds on width, not length
a savage shell is bout 170mm width
200mm is the width, 300mm is a bit too wide.
if you wanna compare dimensions on shells, look them up against the stock shell on towerhobbies. they have measurements of all shells they sell. easier than guessing
sounds like a lot of hassle the topless idea is looking good to me but to be fair i have seen the pics of your truck and i wouldnt be driving it anyway. problem solved for me lol
Here is some tower links to a 300mm body and the specs shown, they have the 300mm measurment at the wheelbase 😕
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXN255&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXSE79&P=7
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEUZ2&P=7
ok, kewl...but i'm not even sure that 300 is what I need...I was just asking if anyone knew if it would fit my truck...I can measure it and find out though...
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNZ40&P=FR
SPECS: Body: Length: 20-1/2" Width: 9" (center) Height: 4-3/4" (un-cut)
Wheelbase: 12"
Wing: Length: 8-1/4" Width: 2"
Wheelbase would be the measurement from the center of one front axle to the center of one rear axle on the same side.
For comparsion here is the specs of the LST size F-650
Length: 21" (533mm)
Width: 8-3/8" (212mm)
Height: 6-1/4" (159mm)
http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXJUK9&P=ML
