ScooterB
- Layton, Utah
I know this topic will definitely arouse interest. I hope I don't offend anyone.
While I have read and read differing theories and expanations it seems that this is a common problem in Nitro model engines of all types. The lower the tank gets the leaner the mixture and is not simply a savage problem. (although the savage seems to have a more severe case than most.)
While reading up and researching I kept thinking that there had to be a better way to create a contant and consistent pressure and flow. I thought about my waverunner which had a fuel pump operated from the exhaust pulses. I did some searching on the web with no results. And then I talked to a very helpful salesperson at my LHS who directed me to Perry Pumps.
At Perry I found the following:
VP-30 Regulating pump
The VP-30 regulating pump is capable of performing like no other fuel delivery system. It delivers an ideal .25 PSI to any model carburetor from a .15 to a 3.0 cu.in. engine. The pressure remains constant throughout the entire speed range, making the carburetor adjustment easy and simple. Once the needle valve is adjusted, the mixture will not vary regardless of how low the fuel or the attitude of the airplane, thus eliminating rich/lean runs altogether.
Price: $41.95
Diameter: 1"
Length: 1.5"
Weight: 23 Grams
Flow Rate: 3.5 Oz./Minute
This description says airplane but it is the same pump that Perry offers in their systems for Nitro cars and trucks.
for more info go to Perrypumps.com and navigate to the rc car and truck section.
While engine size is limited to 3.0 the salesman who I talked to found that you can run two of these (increased fuel flow, same pressure) for larger engines.
I'm ordering two. (CLARIFICATION: 1 FOR MY TRUCK THE OTHER IS FOR MY SONS. 2 Trucks 2 Pumps.)
Price: $41.95
Diameter: 1"
Length: 1.5"
Weight: 23 Grams
