1.0 mugen clutch spring help
big scott
hello all, i just got new nova alum. shoes and mugen 1.0 springs and the springs are not sitting in the grove in the nut??
i have the savage 25 with team orian .26 with stock .25 flywheel and nut. when i put the small washers under the shoes the spring will not sit right but if i take the washers off it works. but i do not want to leave the washers off what can i do???
you guys that are useing these springs and shoes what flywheel and nut are you useing?? thanks much..
also if i need to change my flywheel i would like to get a vented flywheel if you could recoment one that would work with my setup.
Loose the shims behind the shoes. RR aka Robinson Racing vented flywheel.
I have these Nova shoes & mugen 1.0's with the mugen collet nut & a HPI XL flywheel. Crash installed them on my mill.
Its a nice set-up btw, i love it & think you will too.
I used a thin brass shim behind the flywheel nut on this set-up
the pic below shows how it did not line before shimming
thanks guys. i new there was different ways of doing it just needed your advise. I'm gong to put shim under the nut.
another ?
i just got a hpi vented clutch bell is this harden? can i use it with a metal spear gear?
thanks guys..
another ?
thanks guys..
Yes it is & yes you can my man
