J
JohnH
Guest
OK here is what I was thinking. This is basic and just an over view so let me know what should be added or taken away. This is a truck made to be played with not looked at on the shelf. Performance is the goal. I will do a full build up with pics.
1st YES it will be a Savage xss kit---------------------------$358.00
2nd Platinumrcproducts carbon fiber Extended TVP's ---------$178.44
3rd HPI 87245 suspension conversion------------------------$155.00
4th hpi 77065 high speed 3rd gear---------------------------$9.00
5th hpi 87220 3 speed kit ----------------------------------$50.00
6th HPI TF10 3 channel radio--------------------------------$50.00
7th HPI Hellfire Tank----------------------------------------$13.00
8th HPI 17mm hub conversion-------------------------------$40.00
9th Nova Motor mount--------------------------------------$28.00
10th MPI 5470 led switch and charge jack-------------------$12.00
11th hump pack from CED-----------------------------------$22.00
12th ExtremeRC Mods did the engine mod -------------------$125.00
13th rear wing . Blue Grove---------------------------------$15.00
14th 4x msr 8 shocks w/ upgraded spring kit-----------------$80.00
15th Trinity clutch system----------------------------------$70.00
16th Proline bow tie tires.-----------------------------------$44.00
17th rims Blue Grooves--------------------------------------$30.00
18th Tekno tkr1009 revo wing mount.------------------------$20.00
19th body Blue Groove--------------------------------------$35.00
20th Glow Igniter-------------------------------------------$20.00
21st Fuel---------------------------------------------------$35.00
22nd Wingtote roller bag------------------------------------$130.00
23rd 4 6x10x3mm bearings for steering posts-----------------$4.00
24th FLM45700 motor tray----------------------------------$20.00
25th Header spring tool-------------------------------------$7.99
26th Flex Tek lower arms-----------------------------------$170.00
27th Socket wrench---------------------------------------$24.99
28th GH Racing shock towers-------------------------------$60.00
29th BUKU pipe--------------------------------------------$109.00
30th GH racing steering bellcrank---------------------------$55.00
31st GH Racing 47 tooth 2 piece spur-----------------------$33.00
32nd servos 2x 645 mg------------------------------------$60.00
33rd Racers Edge 17 tooth titanium nitrate clutch bell-------$20.00
34rd Picco .28 (Modding above)----------------------------$190.00
35rd Stainless Steel Screws--------------------------------$25.00
36th 8mm hex wrench-------------------------------------$8.99
37th Dual hex wrench set----------------------------------$69.99
38th Flywheel wrench-------------------------------------$10.00
39th Screw drivers----------------------------------------$5.00
Fuel Bottle------------------------------------------------$11.00
To this point the total is around $2,403.40 not including Johns time and all the shipping involved in this. Let alone all the small miscellaneous parts involved. Someones getting a very nice truck!
