FLM Ofna 250 Mid Tank Build
Dazn
In the middle of mocking up a FLM mid tank build and just wondered how people with a similar build have position their steering servos
Reason I ask is because after trying a few different combinations I’ve found the side of the Right TVP to be the best, which will require a longer linkage - but the servo I’m using means that I can’t button up the last skid plate screw. See photos that hopefully explain.
Wondering if anyone has any guide on throttle.
Not sure if it helps as a side note - while looking at the K5.9 - there is a plastic insert that kind of clips into the HSN - I’ve found d that mine had wiggled down - so when trying to reset back to stock settings it was way off - hsn should look like this
Hope this helps someone as the screw head itself is never actually flush with the plastic housing
