SwatKat
OK, si I have my Savage for 1 year, and so far, it works ok.. until 1 month ago, when I decided to have some spring shopping... So I got the maximizers, new tires and pull start.
A weeks ago, after a bash session, I decided it was time to replace things around and also clean the truck.. So, I started tearing it apart. Here are some questions/aspects:
- Found a missing screw on the rotostart plate.. after removing the engine I noticed what can you see in the first pic below. Didn't realize when happened... I think maybe because of the roto.. Anyway, ordered the item. The motor looks ok. Q1. Do you think of another cause? Should I tear apart the inside of the motor to look for hidden aspects?
Q2. When replacing the backplate, shoul I also replace the silicone o-ring?
- Found some used teeth on the flywheel.. You can see it in pic 2. I think it's no problem, but I'm asking anyway. Maybe from the HPI safety stop i have installed. Q3. Am I right or there is a problem?
- Replaced the lower A-arms with RPM ones and I'm waiting for a HPI suspension conversion set. Waiting for the big bores also.
- Replaced the plastic bushings with hpi steering upgrade set.
Q4. How tight should the screws on the servo saver be? Q5. I must use TL on these screws, right?
- Q6. I understand I must use TL only on screws that fits in metal? Do I use also on those on the front/back skidplate?
- Ordered and waiting for the OFNA tank and hope it will reduce the leaning problem.
- Q7. Should I use orings inside all the diff cups and wheel cups or only in diff cup?
- About hpi suspension conversion set. Q8. read that it includes the adjustable upper arms. So will I need the stock upper arms or no?
Expectations after these hop-ups: better handling the truck, more stability, less trouble with rotostart batteries (hope I will not reverse to roto)..
For now the truck sits and I'm waiting for the items.
Thanks for reading and possible replies to my questions.
