HPI RSC # 87245
This is a definate Bankrupter Mod and anyone who has talked to him about the RSC has heard him say "it turns the Savage from a brick into a race-able truck."
all 4 corners get adjustable upper control arms so that you can tune your camber angle.
both front and rear get a new aluminum upper arm brace which lower the roll center of the truck and reduce the amount of chassis roll.
plastic knuckles on the rear of the truck get replaced with aluminum hub carriers. they have the toe angle built in and eliminate the need for rear turn buckles.
on the front, plastic knuckes with aluminum c-hubs and carriers that have built in camber angle for improved turning.
here are some pics of it installed
Quality - 10 - these are high quality hpi parts. Excellent fit & finish
Price - 8- $155.00 at LHS. Worth the price imo
Installation-8 you have to do a bit of filing on the shock tower & bulk head to fit the upper arm brace, not really a big deal.
Functionality-10i am amazed at how fast i can wail into corners and the rear tires do not lift & truck doesnt flip over.
Overall - 9
Conclusion
When the RSC comes up in conversation, most times i have heard people balk at the price. Since i have been running it, i am truly amazed at how much faster i can take a corner with all 4 tires on the ground. As i learn to "trust" it, i find myself going faster & faster through turns to see what it can do, it is like driving a totally different r/c. The tuning ability gained in caster, camber & toe angle is incredible.
basher or racer, give this mod a try, you will not be dissappointed.
RSC Stock Rear Toe Angle VVV
Overall - 9
Conclusion
