1/2 tank leanissue
redneck
so u can't tune sorry
CANADA
ok i am new kinda and why does the savage tank have the 1/2 tank lean issue what is the cheapest solution thanks shane
What savage do you have? I have a Mid-Tank kit part number PRC125 which accepts the 250cc tank. This kit replaces the stock radio box. I do stock the tank and most other hardware needed for doing this mod.
It is designed to directly mount to the PRC or FLM Chassis Kits but will fit the stock savage as well but you will need to either drill a hole in the tvps if running the 21/25 TVP's or sandwich the X TVP's between the PRC125 Plate and a larger flat washer. It works wonders and removes any issues with HTL also gives for a larger tank. I also offer a PRC112 which accepts the Hellfire 150cc tank. Either of these can be drilled for a different tank as well.
The PRC125 requires the X style front bulkhead.
+1, 250 cc tank. fixes lean issue, protects the tank inside the tvps, runs a long time.
is the stock tank only 150 right notn 250 and i don't want todo the nid tank mod
hey larsen whats the price tag on your ofna 250cc tank set up from start to finish just outta curiousity. does it work with the x and XL? you can PM me or let me know here either way. thanks
