XL Spur gear
ya since it came with the truck i would stick with that actually.. once the mesh is proper it will last almost forever.. i admit there more expensive to replace but that wont be an issue if your mesh is ok!!!
I ask this because I think after a few bad jumps my motor may of moved and stripped the clutch bell. The spur gear didn't look to bad but I couldn't get a new one.
I meshed the gears using the paper in the manual as per instruction, after a short run I noticed some makes one the new clutch bell, irregular marks.
I can get a plastic one now, which is why I asked.
Yes and cheaper.
I was told this was a option the stop the clutch bell from being stripped, again why I came here to ask you guys.
Cheers
