cen differential mod
609savage
dirty jerzey
ok, I'm wondering what will happen if i do the cen diff mod to only the rear diff and leave my front diff stock...will the gearing stay the same or will it really be different. cause when i read teh article in rcbashers "how to thread" he said that it will lower your gearing..any ideas?
Ok Here's why you should not do that.
The ratio's are different and they will tear each other up!! DON'T do that!!! Put both Cen diff's in or as Blazer X said take out the front driveshaft if you change the rear-end gears but kinda defeating the 4x4 effect there aren't you!! PEACE and good luck.
fredd...well i don't plan on doing just the rear it is that i bought the one cen diif to try the mod 1st and then i will do the front one once i get the rear finished..i never planned on running cen diff in rear and the stock in the front..i was just curious ...
oh yea, makes sense. just don't run a doggy in the front yer all set. shout to us if you need any help with the cen diff. :resp:
