How Does Mt Trans Shift?
GOT NITRO
I Bought A Used Savage 21, And I'm New To The Hobby. And I Drove It A Couple Times But I Never Hear It Shift.. Whats The Deal?? How Does It Shift?? Is A Servo Hooked To A Linkeage Somewhere That I Haven't Found??
Is There A Way To Adjust It ? I've Drove It As Fast As I Can To See If It Would Go But Nothing Happens! It Only Gets Up To About 25mph
just wanted to say welcome to the forum GOT NITRO and I'm in agreement with everyone above get it tuned right then see if it shifts as these nitro engines depend on rpm's to shift so if its not hitting a high enough rpm it doesnt shift so do that and let us all know what happens and we'll be here if u need more help, so again welcome to the hpisf family!!!!
HEY I'm BACK WITH ANOTHER PROBLEM!! I GOT INTO THE TRANS BUT I CANT FIND THE ADJUSTMENT KEY!! IS THERE ANYWAY TO GET IT ALIGNED WITH TAKING OUT THE TRANS AND TEARING IT APART??:stickspank:
:lmao3:
HEY I'm BACK WITH ANOTHER PROBLEM!! I GOT INTO THE TRANS BUT I CANT FIND THE ADJUSTMENT KEY!! IS THERE ANYWAY TO GET IT ALIGNED WITH TAKING OUT THE TRANS AND TEARING IT APART?? THE ADJUSTMENT KEY IS NOT IN ITS HOLE. I GUESS THE GUY I BOUGHT IT OFF OF DIDNT PUT IT TOGETHER RIGHT MAYBE??ALL I CAN SEE IN THE HOLE IS (QUOTE) THE CLUTCH PACK SYSTEM.:lmao3:
Because second gear is not engaged you will see the clutch through the hole, as it's spinning faster than the sprocket (the same speed as first gear) keep turning till the hole in the sprocket and the adjustment hole line up, it might take 5-10 turns.
:good boy:i'll get u guys some pics (my video camera has a bad battery:lmao3🙂 i see if i can get a pic of somthin cool:buttshaker: and again thank alot for the help!!!
