Grinding stainless brakes???
xl1
New Member
I installed brand new stainless brakes and when I whent to test them they are making an awefull grinding sound?? Will this go away after I break them in??? Thanks
It should go away. Before I installed mine I took a dremal with a sanding bit and ground the rought marks from the holes being punched off.
i also used to have problems with the stainless brakes they used to rub tight against the clutch bell and would force the brake disc off the hub i to took a dremel and ground off some of the disc
That's a bent mill plate.. I did the same fix b4 I replaced the plate
