NickMind Savage 25 Rebuild
nickmind
San Diego, CA
Hey all,
I'm as of last week I am almost done with my savy rebuild. It's an Savage SS that has been clean from its purple deamons. (Death to Purple). Along this the cleansing, a few hop ups were added. Here is the list:
GH Blue Steering BellCrank w/ Bearings
GPM Blue Engine Plate
GPM Blue Arm Lock plates
GPM Blue RollBar
HPI Aluminium Diff Cups w/ new 4 gear diffs (added some bling, look below)
BEST CVD's for both front, rear, and center
Newer Steering Servo Hitec 5945MG (Have HS-5955TG on its way)
Lunsford Titanium turnbuckles
HotBodies Aluminium Shocks with Blue HPI Springs.
Polished up the out drives and Diff cup.
That's right
No more purple. Here was my process for the Lower BulkHead. Started by useing a can on easyoff.
And the lower plate.
I got this.
After that I started using some "600 grit" sandpaper to remove the rest of the white. And got here.
Then I used 2500 grit sandpaper, and the dermal with some polishing to get here.
Sorry I hit enter to soon. Here is some more work.
Before shoots of the front End.
After Shoots of the Front End
I had to mod the screws in the GH BellCrank.
Here is the center
Close to the finish line.
OFNA Throttle Linkage
Some finished pics with the wheels and body are to come...
skip the 600 go straight to 1000 other than on the tooling marks and from the 1000 Mothers and a rag. 2500 is a waste of time. No dremil it adds swirls
Mirror results every time.
That mill plate is not clear but is the running joke. Its against a mirror for the QC shot. But de-ano weekens parts just FYI this one lasted two weeks b4 cracking. They need the hard facing it provides
http://i83.photobucket.com/albums/j314/justin11275/IMG_0362.jpg
Your not going to upgrade to X cases?
What was up with the GH bolt?
Mine have some slop now as well 🙁.... 3 gals old
Last ? what pipe is that it looks bloated.
very nice, I also got rid of the purple, and I'm aiming for an all silver truck, one day ill get there. again looks amazing. rep.
nice job nick
should go with an x style radio box
I just did, its a little better. more room inside and easy access
I would have to disagree with this, my process in cleaner and way faster then I'm picturing the process you are refering to. I'm using the 600 grit to remove the white off the plate that the easyoff did not get. Then I'm using the 2500 to get the mirror affect. Then I use the dermal to fix the spots that the 2500 grit did not get.
nice job nick
Good Idea, I'm going to ebay as we speak. Plus I have a new steering servo I need to install. So I might have to do them together.
Cool Ive yet to find a polishing tip for the dremal that does not leave a mark on the finish. How long does that method take? After easy off mine is 8-10 mis per a piece faster on flats then in threads. I use the 1000 because the chemicals in the mothers don't need it finner than that to take it to a mirror finish. But if you hit it with 600 first those marks must get sanded out. Hit the pieces you have done with the mothers! You will be stunned if you don't use a dremil that is.... it will make it worse. Just a soft rag and don't push down!!! It does the work for you. Pushing will leave marks too.:resp: you will be able to place it on a mirror and not see any difference Between the two!
