SunkenMetal
- Location
- Houston Texas
So I have been thinking about making a limited slip or posi traction whatever you want to call it diff for my savage. But I wanted it to be adjustable so I can tune the diff with out having to take off the bumper and the screws to remove the diff cover and take out the diff. so I figured a set screw in one of the output cups to put pressure onto the spring inside the diff. That way you just have to remove the dog bone to tune your diff. instead of removing the diff taking the diff apart cleaning out the diff silicone, then putting it back together with a new weight silicone.
Or, use 2 wedges and a set screw threw the diff cup to adjust the tension on the spring… anyways I am brain storming, and drawing it up so I can see my ideas and work out any problems before I start drawing things to scale…
Here is what I have come up with so far...
I am to lazy to label everything in the drawing, and it’s a pain to do in Mastercam, I just color coded everything and here is a key to what everything is in the drawing
White=Bearings
Red= output cups
Brown= spring tension set screw
Green= Diff Gear
Grey=Diff cup
Blue=Friction discs
Yellow= Spring
Pretty much the only thing that would be stock is the Gear… I have made gears before but I just don’t feel like drawing it up or doing the math, I am lazy like that…..
So what do ya think of my idea, or has someone tried it, or sell it already.
White=Bearings
Red= output cups
Green= Diff Gear
Grey=Diff cup
Blue=Friction discs
Yellow= Spring
