AoD
- Location
- Hammondsville, Ohio
Go HPI!!! With the release of the Savage XL finally here, they also included some goodies for us Savage X owners!
Savage XL Chassis Conversion Kit
At an MSRP of $90.00, it's not a bad deal as it comes with the TVP's, Dogbone, and the engine plate as well! Not a bad price considering that's from HPI directly!
Now, they haven't forgot about us X users with our weaker drivetrain either!
These will upgrade the drive cups and dog bones to the newer and tougher dogbone style drivetrain of the XL! It is a bit expensive however, with the MSRP of $110.00. Also, this only upgrades the actual differential to wheels only. It doesn't include the transmission to differential dog bones.
HPI Savage X owners can now upgrade their truck with this Savage XL Chassis Conversion Set. This set includes 55mm longer TVP chassis plates that give the truck extra stability over rough terrain. The extended chassis plates are 3.0mm, thicker than the stock 2.5mm plates so they’re stiffer and tougher… perfect for extreme driving. The chassis plates have Savage XL logos etched into the chassis to really make them stand out! Also included is a 3mm thick engine mounting plate and an extended rear drive shaft. This is a factory engineered conversion set that is made to fit perfectly for quick and easy installation on any Savage X truck.
We recommend using the Savage XL body for the best fit, but some of the larger truck bodies can also be used.
Note: Original Savage trucks (pre-Savage X) will also need 1 package of #86709 Engine Mount Brace 7x7x74mm (2pcs) for the conversion.
Dogbone and Drive Cup upgrades!This SUPER HEAVY DUTY DRIVE SHAFT AXLE SET will upgrade any HPI Savage truck to the ultra-strong outdrives and dogbones developed for the Savage XL. The extra-thick steel dogbones deliver the durability you need for massive engines and bigger trucks. The set includes 4 dogbones, 4 inner drive cups, and 4 outer drive cups that upgrade the front and rear of the truck.
LOL
