Integy suspension not fitting on my Xss 4.6
triniheli
Trinidad, West Indies
I just got my integy evolution 3 suspension kit for the savage x and the lower control arms are not lining up. I tried all 4 lower arms and none work.
Has anyone had this problem. I am so disappointed here!!
i know when your putting the losi shock conversion on a sav x you have to switch out the stock sav x a-arms for the original sav 25 a-arms for it to work!! not sure if what your talking about is the same or not!!
Is there anyway we can see some pic that would help out bud
ok guys...I'm so embarrassed...
it's fine...I just needed to apply a slight bit of force on one side.
thanks
Just make sure that they don't bind before you finish putting everything back together. Hold the truck off the ground with the upper and lower arms hanging free(no shocks mounted). And also make sure the truck is as level as can be. Then lift each arm one by one and let it free fall. If you don't get full swing, it's binding somewhere. Just some more input for you to consider.
aah ok then i have seen them before i just couldnt put a finger on were i had seen them before! lol
