FLM Ofna 250 Mid Tank Build
I didn't plan to run this particular one as its build for show, beside the rotostart can't be reach due to the rear pipe blocking access to it. If I want to run it, I need to convert it back to pullstart or inside the pipe on the side, which I don't want to do. As for the runtime, I really don't know as its about 75cc larger than a regular Savage's tank.
👍that looks killa bro 🔥👊
Bit of an update - few bits done and taking longer than I thought - but bit of back and forth - getting there:
I got stumped when converting a 2-speed gear box to a 3 speed because of the ideler gear - the ideler gear in the 2-speed is a lot thicker than the 3 speed can accept:
This is with the standard ideler gear and the gears would not close.
There was so much give in the gears when building that I thought I needed to shim - so I shimmed where I thought was needed and then found that it was best to stick to the guide because if one shim solved a bit of wobble in one gear - this would mean a tight gear somewhere else - this took me hours of back and forth - bear in mind that - also - when you screw the gear box case together - there is actually more tightness than you would think
the lateral movement could only be solve by forcing another C clip
The gear box I left dry - so no grease etc - except for adding a bit of 3-in-1 oil on the gear here as the rotation was not as free as I was hoping:
This is a one way bearing - and I found some rust - so used some safety cotton buds to clean as best as possible - I wasn't happy with the gearbox spinning - and you need everthing to be 'loose' to prevent extra strain on the engine.
After finishing the 3-speed I mocked up the rest. I forgot to mention that the ideler gear needed a few shims to centralise against the 3-speed assembly and I used these shims here:
I have a Dynamite exaust and header on another savage and cannot find just another manifold - which is what I need - so instead - I purchased a XL exhaust header becuase the sweep is a lot better - in turn - means better exhaust outflow and less restriction - here we have the standard Savage header vs the XL header:
Can anyone tell me what this if from:
Some more photos of the build so far - just mocking up:
And these as well
And size
I've found that dabbing some alchohol into a microfiber cloth - and then setting the drill into reverse - while the screw is in the bit - cleans a load of much off - then when putting some fresh blue loctiteon - it secures better
Ye you gotta put the 3 speed idler gear wi the 3 speed 👍👊
How many shimms you got on 3 speed centre cluster ? The old gears av 1 shimm n new 1s av 3 shimms ? There still slop -play on centre cluster wi the 3 shimms tho ? 👍👊
Ye them X headers get super hot n melt the coupler n zipties on them Lrp beasts nowt but probe deffo nd XL header I grabbed a bynamite 053 n jp2 pipes no more melting issues 👍👊
For the extra shims in the three speed transmission - I used some extra shims to push the idle gear closer to the main cluster - and then an extra clip mentioned above - there was still slop but am hoping that once in the case the gears will stay nicely lined up where they are supposed to be.
On the theme of gears - I'm having a hard time trying to find the right combintaion of Spur and Clutch Bell - it seems that anything larger the a 47t spur won't work - anyone else come across this before?
Also, I think I am going to need to get a thicker spur gear as the contact between spur and clutch - once the engine mount is around where it should be - does seem like much - bit out of ideas.
Wot clutchbell you using ? N the older spur gears are lot thicker than the new Hpi 1s ? Cant you shimm ya clutch to bring forwood fo full contact ? 👍
