@Vinni
Evening Vinni, don't now yet, got to find the rest of the parts needed to finish it 1st. Only spare mills I have at the moment are:-
1... HPI Nitrostar s25 (4.1cc) from from an old Savage
2...That new Kingtair .32 (5.2cc)
3...Thunder Tiger .28 (4.6cc)
All 3 run well with great pop. Don't want to use the Kingtair on it, maybe will put the S25 in it. The Thunder Tiger is abit of a Frankenstein mill. Bought it used from eBay, supposedly in good working order, well that was not the case as this mill has an internal OWB, only thing was it was missing, yer great I know. But modded in internals and fitted an OS starter shaft so that it now uses a external 12mm OWB. It did have and still does have great compression tho. Last time I ran it, which was on a bench I couldn't get a good tune on it. Having carb trouble with it, think could be wrong needles in it as had to make a good carb from two. Only carbs I have played with and know are the ones that come on HPI/Force/Kingtair mills & the 3 needle K series carbs which I ain't to keen on. Not got a clue on the one on this.
On another note finally tracked that UPS package down and yes I now have 2 Motorsaver filters for the Savages. So If you want 1 still, PM me over the weekend and see if we can come to some arrangement.
