Mvtepixels
Yes, on the fast passes I have it set to 50% correction, on general bash it's off, but even with a giro it's a struggle to maintain the truck in a straight line at those speeds.Have you got a giro on that?
Would you please post a photo of where you have installed it so i can fit one myself?Yes, on the fast passes I have it set to 50% correction, on general bash it's off, but even with a giro it's a struggle to maintain the truck in a straight line at those speeds.
It won't fit in the original motor mount, you need the Alza racing center diff kit or the Draco center diff set.Will your motor your using work on mine with stock motor mount or will it need a different one?
Castle Mamba Monster X 8S, 33.6V ESC W/1520-1650KV Sensored Motor
