Aluminum Heavy Duty Rear Hub Carrier Orange
As simple as removing the old and installing the new, make sure to clean and reoil the bearings....
Hi Jam, its not very clear but these are the parts already fitted its not standard HPI Hub Carriers.311274537_462875879142226_5178528599648071279_n.webp311722552_469259388503875_6342090726851057521_n.webp311890390_469259398503874_1466891912494692567_n.webp
Yes I would say you already have good parts on the rig, why bother putting orange on unless it is simply for the color
Your right Jam it was for the colour and to give me something to do, if you think there is no point i shall leave the old ones on! Haha.
I have this part, does anyone know how to fit it and is it easy?View attachment 10798
They fit like this Paul.
1673243660986.webp1673243676349.webp1673243706733.webp1673243732069.webp1673243750991.webp
With them fitted you don't need the rear turn buckles so these can be removed. The 3 holes in the top of the hub are to allow for the camber of the wheel to be adjusted. The centre hole is the best one to use with it giving the rear wheels a small amount of negative camber but seeing as yo have adjustable top arms you can fine tune your adjustment to what you what.
These parts only fit the rear by the way.
View attachment 10803View attachment 10804View attachment 10805View attachment 10806View attachment 10807
Thanks...
Well adding color is a personal choice, after all it is yours to express your style on, what I say matters little, that is what is so fun about the hobby, making the rig yours...
