More Spur Gear Issues
-SaVaGe X-
Ontario Canada
I stripped another spur gear and when i was replacing it i spun my new one and it wobbled. whats wrong??? did i put it on wrong??? ive taken it apart and put back together quite a few times so i don't think i put it on wrong. Tell me what you guys think.
any help will be greatly appreciated!!!!!!
thx
Make sure not to tighten it too much......i always locked mine down all the way and it had a wobble, loosened it and the wobble was gone..
Hey X.
First off, I accidently pushed the edit button on your post here. OOps.lol
Its a Moderator thing. Sorry.
Nothing was changed as you can see.
So... Just incase you were wondering why is says "last edited by", Now you know.
Now, for your post,.. Hold the truck firmly after you've tightened the engine bolts.
Get a grip on the heat sink and try to rock it in every dirrection.
If you feel ANY movement, there are some motor plate bolts that are loose
somewhere.
Also, check for some associated bolts and screws in the area of the engine mount
Hey X.
Nothing was changed as you can see. So... Just incase you were wondering
don't worry about it doob!!! everyone makes mistakes.... i don't think i would have even noticed if you didnt tell me.lol!
OOps.. I just deleted all of your thread history, SavageX. SORRY!...lol
Just kidding.
Ya know...All these new buttons I got all cool.... Hummmmm I wonder What this one
does?..... DOEUGH!!!!!!!!!!!!!!!!!!
I had the same issue once too. What I did was rotate the slipper clutch hub, hub key (the little metal rod that hold the clutch hub in place) and slipper clutch plate around untill the wobble went away. Since each of those pieces can go on 2 ways, each 180 degrees apart. Do you know what I'm talking about? My wobble was very very concerning to me and I even took my whole truck apart to get the tranny out, thinking maybe the input shaft to the tranny was bent. it wasnt so i put the slipper clutch parts back on in different orders untill it went away.
diff problems
this is my 3rd diff gear i cant figure it out can someone tell me why they keep brakeing
better start a new thread.
this one is referring to spur gear issues.
diffs are different story.
start a new thread with more info about your problem so we can help.
