crazymanrols
hi everybody need some help I'm sure this has been mentioned before but I'm at a loss,,I have a stripped head button,,anyone offer a insert service anywhere? or any ideas how to fix
thankyou
thankyou
finding one is near impossible hpi are not making any parts at the moment!!Buy a replacement button is your only option
the force 38 is a 5.9 the 36 didn't have the holes in the right place,,will confirm if it fits when it arrives for other users info!Thats a force 38 head button, is it the same as the 36?
the bore size is different,this i managed to do,,it was also to deep into the cylinder,,I patiently filed it down until there was clearance for the piston,,then had to notch the outer edge to allow for head bolts to fit straight,,it failed to start,,just kept going tight as soon as throttled engine failed to turn nearly burnt out rotor starter....I think the depth of the button is my failure,,as I don't know how far it should fit into sleeve as my stripped button is being sorted by a friend of a friend and don't know if or when I get it back..any ideas would be appreciated!!thank-you for replying.Yes surely they can’t be that different they both come out same factory?
Op has a k5.9 he is trying an f5.9 buttonYes surely they can’t be that different they both come out same factory?
I've just bought one off ebay a couple popped up,,if not I have a second hand one you can purchase.Hi everyone, I am new to this forum but not RC.
I have accidently stripper out the thread in the K5.9 button, unable to get hold of one (UK) Is the anyway to repair? I guess there is no alternative part to use,
Thanks
