The transmitter is a TF-20EWe need to know what radio system you have
Most 2.4Ghz receivers set the fail safe position to wherever the servos are when you bind the transmitter to the receiver. What transmitter/receiver do you have?
I run spektrum and when I start them up in bind mode, they don't move the servos, then I bind and whatever position the throttle and steering servos were at becomes the home position when signal is lost.
The transmitter is a TF-20EMost 2.4Ghz receivers set the fail safe position to wherever the servos are when you bind the transmitter to the receiver. What transmitter/receiver do you have?
Actually, page 7 in that pdf.Here is a link that will download the manual for your transmitter. The instructions for how to set up the failsafe are detailed on pages 9 and 10.
https://www.hpiracing.com/assets/documents/instruction_manuals/106214-tf20_rf20-glb-m-v2.pdf
