Need help
Thank you just bought the truck used and don't know much about it wheres a good place to order engine parts from I need a starting shaft and starting pin and the one way bearing
You can usually get the OWB to grab again if it's just gunked up. Take a piece of paper towel and twist it so it barely fits inside the bearing. Soak the towel with DA (denatured alcohol) and pull it through the bearing. Spin the bearing on the towel in both directions to loosen up the gunk. Then put some light oil (after run oil usually works ok) on it, clean the shaft it goes on with DA, then give it a try.
