Running in circles.
RaiderHam75
Is the Integy aluminum steering bell crank worth it? Or any aluminum up grade? I'm running a high torque servo but the steering just isn't there.
Try a different diff fluid as well. Maybe tighten your servo saver spring as well. If something is sloppy I would look into what is causing it, bearing, bushing, etc.
Also run a hump pack battery for the electronics. You need more amperage! It makes a huge difference
I run a 2700 mah li ion with an ultimate bec so plenty of power. As said above this is the MOST important ingredient in a good steering truck.
