Savage keeps breaking differential pinion gears
Why does my Savage XL 5.9 keep breaking differential pinion gears?
Landing jumps on throttle is most common cause of that gear breaking off teeth..... when landing from a wheels in the air situation land the truck off throttle and make sure your gears are properly shimmed when you install new parts...
should I replace differential gears with upgraded bulletproof 29/9 gears?
Thats personal preference actually. I have the stock sintered gears in my Savage and have no trouble exploding gears, just remember to release the throttle when doing jumps.....
I just replaced my 43/13 for 29/9 a lot more durable, and top speed I think, and made sure everything was shimmed, like jam said. make sure bearings are not needing replaced, they get a lot of play in them when bad, causing bad gear mesh!
Okay thanks but where are you finding parts for it can't find the gears anywhere
I had that issue many years ago with the 21 style diff cases. Upgraded to alloy cases (not the cups, the actual case the entire diff goes in) so I could shim properly and ran the machined gears available at the time vs the sintered ring gear. They would last a while as long as you kept an eye on the bearings.
With my X and the newer style diff case that splits so you can pull the diff, I haven't bothered upgraded the case to alloy, but I did upgrade to the BP sintered ring/pinion. Haven't had an issue with diffs since I installed them 4+ gallons ago.
Landing a jump while on the gas is probably the worst thing you can do to the diffs. Locking the brakes up on high traction isn't the best for them either.
