It's not the cooling head my mistake, it's this bit what I needWhich thread? Is it the one for your glow plug?
Thanks mate I've just ordered it Any advice on fitting it as I've got a spare engine and took it off that and put it on the one I was using and it didn't run right and was a nightmare to start! When it was running fuel was leaking out the side of it a little bitOK that's what I thought you was talking about. That part number is (hpi 1444).
Will changing the head really make a big difference to the tuning? As I've just had it tuned perfectly with a 3 speed transmissionTake the head off and clean everything with nitro cleaner. Check fitmit and reassemble it set LSN and HSN back to factory tune it from that point and see if that helps.
