aluminum shocks upgrade
Guys I have a question. My savage came with the HPI aluminum big bores (alum body, gold shafts), and they leak from the bottom. I see this is very common, after searching. The problem is, the bottom cap seems to be a complete unit with the O-rings inside, and I am not seeing a way to disassembly it to change the O ring? Any advice? Thanks
https://www.hpiracing.com/assets/do...a720_big_bore_aluminum_shock_set_glb_m_v2.pdf
@spawn_x see link for big bore aluminum shock instructions.
Thanks! This confirms it though, that the bottom part is pre-assembled. I went ahead and ordered the regular plastic big bores, seems like feedback is they don't leak like the aluminum ones
Pre-assembled yes, but the bottom cap threads out & is rebuildable. I've been looking into buying a set of these aluminum big bores.
