Eating second? gear
francis Labarbara
West Virginia
My tranny has taken all of the teeth off the 39T gear again. I have 2 coming. Is there anything I can do to help it live? I thought the LRP 32 took the first one out but I am running a .28 now.
The last time I ordered a new tranny and changed the guts out so the OWB, bearings and clutch are almost new.
Gear problems almost always because mesh is off, debris or sudden stoppages. I recently killed a diff pinion/spur when bearings failed and mesh changed. I'm curious what you find out. Good luck.
And try to find a pre-X gearbox. The X gearbox has a flaw because of the way it is built.
The older ones will work better and if you have a 2 speed there is no need to take the top off.
