HPI Savage 25 won't move
sticky 2gs
My wheels wont move on the ground but off ground they move fine and my throttle cable linkage keeps shaking when i turn on the truck on switch wat could be the problem
with the wheels not turning on the ground I bet your servo saver is loose, as for the throttle jerky it sounds as if the servo may be having a problem.... or your signal to the radio is having a problem, what battery pack you using to power the truck ? a 4 cell or a 5 cell hump pack??? those could be causing an issue due to low voltage also...
I just have 2 aa batterys for the truck i put new one's in and how do i tighten the servo saver
either way , the small expense of a rechageable 6 volt pack will 1 last longer and 2 deliver plenty of power for a days bashing with no trouble at all. and just think no aa batteries to go dead in your rig.....
Just remember to treat it with some care and a rechargeable pack will last for years too boot...
Ok but is it suppose to be 4 batteries on the truck
Yes if you remove the 4 cell pack holder you will find 4 aa batteries, 2 on 1 side and 2 on the other.....
do you have the manual for your rig??? if so I recommend reading thru it and becoming familiar with your truck......
No i bougt it used thats maybe while it swithing i only changed 2 battries cause it was fine the first day i put the 2new batt in 2nd day is when i had the problem I'm have to take the cover all the way off
By all means remove the cover and change all 4 batteries at the same time and download the manual linked by @Rooky and become familiar with your new toy......
He ain't the only old guy. Lol
This is true. But I've known Jam a while, so it's ok to poke fun at his age alot. 🙂 Plus, he has a definitive grumpy old man aura. haha
