Mid tank lean, please help!
yes you can tune it to be rich during full tank operations and when it gets half tank it outta be ok till the tank empties.....or try making the fuel line longer as some others have done to try to get it right....
there is a ez trick . if you got a extra antenna tube and som extra fuel line . cut the antenna tube about 3/4ths . then lift the fuel cap up . there is a hole put the tube in there . then 2n 3/4ths fuel line . feed the fuel line on to the tube and place it in the lower part of the tank . this works great . then place some rtv around the exhaust gasket on the motor . allow the rtv a lil time to get tacky and make sure both parts are clean before putting back together . works goodImg_151231073927.webp Img_151231073837.webp
Lower the tank in the chassis.
I posted this before.
Rear tank mount
Front tank mount
