Hpi savage x 4.6 loses power at top speed
Kiffa007
New Member
Hey I am in need of help. I own a savage x 4.6 and so far have loved this beast of a truck. The issue I have had lately is the truck loses power at top speed and chokes and then regains power again. I have broken the truck in and tuned it correctly to my knowledge and have ran it numerous times. I'm not sure why this is happening but any help or advice as to what msy be the issue would be so greatly appreciated! Thanks in advance 🙂
Gotta be your carb setting. Or an air leak
Thanks Rikkidy, I'll check the carb settings again. When your referring to an air leak - do you mean in the fuel tube somewhere? I actually did replace the fuel tube (all) but haven't tested it yet. Thanks for your help!
May be running a bit on the lean side. Riches it up an hour (1/12 of a turn) at a time.
Thanks Gaj,
I will richen it up again bit by bit and see if the problem goes away. Cheers for your help!
