Rubenator80
Would i be ok using a 52T spur gear on a 15 tooth clutch bell? Please advise. Thanks
It should fit without modification. Go ahead.
What engine/tires are you running? Just curious.
The only time I ran that low of gearing is many years ago when I ran an OS21RG. Wasn't a stump puller of an engine, but it was reliable and last a long time. I ran standard old HPI tires back then.
What spur/clutchbell do you have now? I don't know what "stock" is as I've never had a "stock" savage.
Oh, I thought you were wanting to buy something new, not ask if what you had installed already will work ok.
Yes, it should work ok.
If it runs ok (doesn't over heat) and shifts ok but seems to top out pretty quickly while the engine sounds like it can take more, then try a smaller spur like a 49T and see how it does.
The grey boxes are combinations that will fit the chassis. So, you can use a 49/52 spur with a 15 bell.
I'm currently running a 47T and 16T bell on my savage-x, so not sure if it's built a bit different or what.
