I'd go with a battery that's 5,000mah and 30C or better. The Nano-tech batteries are pretty popular for the Savage Flux.What C rating do you guess suggest for the flux hp xl? ??
Does running high C rates like 60 & above have any effect or?
Or purely overkill.
The electronics in an RC today are very good but they aren't personal computers. There is no correlation between computer ram and C values in an RC battery. You are only limited by your wallet. You should have all the information you need from the above answers.
Ok
I have a 6000 99 C battery
That means:
6A x 99c = 594
That's about 5 times the draw yet savage needs. Is it overkill then? Is my c rating overkill?
Or, even though it's much more, the savage utilizes the additional c rating?
If we do the math in reverse, the savage really just needs:
Assuming I want a 5500 mAh battery
120 / 5.5 = 22 C
See reply #5 and #6, and read over. Go play with your car.![]()
Like the video said, get the higher c rating and the battery will not be working as hard as a lower c rated one will, heat is the enemy and if running a higher c rated battery will help keep the battery cooler while running...
that in itself is what you would want......
I have to agree with X and Greg and stop over analyzing this and buy the best rated batteries you can and call it good....
