SavageKid93
- Location
- New Jersey
What up everyone,
I'm breaking in my XL savage, on the first tank of static break in the temp hit around 120 F max. I had read and saw video where they say 200 is a good temp. If I raise my idle speed my weeks start turning. So my quesion, is what should I do with my idle, let it be or increase?
Thanks!!
Thanks!!
needs to get above 200 degrees to even start to wear in properly..... you may have to lean the high speed needle a bit (turn clockwise about 1/8 a turn) to get it there but even then is going to take at least 3 tanks to start getting it tuned in,I usually drive my new engines around for a couple of tanks while not giving it full throttle....also when you shut if off between running it put the piston at Bottom Dead Center to keep it from seizing in the sleeve and damaging you new toy.....
