shocks
  • Thread starter Thread starter trebreeden
  • Start date Start date
What do you mean by tighten ?
Do you have the aluminum threaded shocks that are adjustable?
If so not really, you might want to run thicker shock oil, check your gearing (stock gearing is 47s/17c)if your running the stock clutch shoes and springs that might be your problem, and if you mill (engine) has a good tune it should pull wheelies.
Max lifes clutch shoes-
http://www.amainhobbies.com/product.../n/Dynamite-Max-Life-Aluminum-Clutch-Shoe-Set
Mugen 1.0 clutch springs-
http://www.amainhobbies.com/product...products_id/1798/n/Mugen-Clutch-Spring-10mm-3
i believe it has the stock clutch shoes and springs and if i change those will it pop wheelies
lol ok thanks but the engine not stock it has a .28rr axial motor
and i have a savage x 4.6 will they fit that
okbecause i was o the website and they said its only capatible with mugen buggies and truggies and frddy i don't kno i got to check when my car come out the shop
ok now i just recieved my shocks how do i assemble them
