candre23
I purchased a set of SPI wheels for the savage build I'm working on. I was told that I should get 17mm hexes, and have the center holes drilled out to 12mm. I got the 17mm hexes, so that's no problem. The problem, as you can see in the pic below, is that the axles are quite a bit smaller than 12mm. I'm wondering if these large lock nuts would be what I need to make this work? I'm thinking the raised part on the back of the nut would fit into the hole in the wheel. Other than that, I'm not sure what I can do here.
