hi candre.... I thought i would chime in... thanks combuster for pointing him in my direction...
I had the same mentality as you... GO BIG, FAST, or GO HOME
And with the new brushless power it was definitely the right choice.... BUT A VERY EXPENSIVE ONE!
Maybe you have seen my videos and seen how much expense i have not spared in building my truck...
Its extremely fast for such a big truck...It doesnt over heat.... I have tried to keep it as lightweight as possible (but looks like its only going to get heavier as it needs to be more reliable) But all this has come at a cost.
If you want to build a completely custom truck.... You are going to have to rethink your motor options and size of the lipos you are going to run... I am currently running 6s which is the minimum... but most here run 4s-5s because 6s is uncontrollable with the stock motors and lengths. My 6s due to the motor having more torque at a lower kv means the motor can handle up to 9s which is what i am building the truck to withstand now ( The tranny cant handle 9s so i am installing a centre diff and some alloy bulk heads from GH so minimise any diff movement).
The truck has great air control with the right wheel/tyre set up and makes it a whole load of fun to jump... But this comes at a cost.
If you have bad landings, your a arms will bend more than usual, resulting in lots of bent dog bones. A arms are fine as they are flexible and cheap to replace. But going longer definitely means more weight is transfered to each corner in tumbles and cartwheels.
Going wider to match your length also take a small toll on your wallet...
I have done things which most probably no one would do or recommend.
I run spi wheels which you have mentioned, and they give a great look... But i also use the XL Wheel extenders for even more offset...
It makes the truck look sick cause its extra wide.. It doesnt handle that badly either, as you can see in the vids i can drift it nicely on grass. It is not way to wide and long for a track, but hey i don't race anyway!
I also like seeing a huge RC Truck ripping across the grass at 50mph rather than seeing a smaller truck. Anyway what ever i am rambling...
If you have any questions, just shoot me PM or ask me in my build thread and ill get back to you immediately.
Here is my latest vid if you haven't seen it. You can see i use the SPI rims for handling with the lowered suspension.. .and then when jumping i raise the suspension and use my heavy MOABs which give great air control....Tell me what you think.
http://www.youtube.com/watch?v=-LvDEGlTetw
