TripleSix Savy
losi arm with a flat head screw. Fit mine bud.
http://i83.photobucket.com/albums/j314/justin11275/Mid mod/CEN018.jpg
On this one, you can see the cut marks on the horn from the the cut that I needed to do to make the top set up work.
Yep, that hack linkage is still holding since I built this pig. "ant broke don't fix..." (to be honest I never got around to getting another linkage kit.)
http://i83.photobucket.com/albums/j314/justin11275/snapo stuff/DSC_0186.jpg
I ended up using the horn that come with the ofna linkage stuff that I used for the T/B. It was just a tad bit longer so that full throw left or right it wouldn't hit the servo mount or the servo.
On this one, you can see the cut marks on the horn, from the the cut that I needed to do to make the top set up work. All screws were ( and are still ) flush. Extra screw is not needed if you have the thickness of the screw (wide), in its female threaded part (deep), you are max holding power for that fastener. No point in long screws...
WOW! Where did that second pic come from? Wasn't there 2 seconds ago! How you liking that second setup? I like it since the servo is tucked up and completely out of the way of anything!
edit .... added text too ... it works as good as the top one. No issues.
that will let go on you ...
I will be looking into another soon. Hopefully this will last for a little bit. Got a couple bucks into this already, and mama is still freaking out since I'm still not working!:cussing:
Well, finally got my FLM servo plate today and got it all together! Got together with Hypnotiq and went to bash a little! And when I say a little, I mean a little. We get to the spot, get fired up, I hit the first jump and flip it, land upside down, and when I flip it back over, rear shock cap broke. Game over for me. Anyway hit up the lhs, and they have nothing. So thats it. Head home and shelf it. Nope! Hyp gives me a cap off his truck! Back and ready to do it again another day. Hopefully soon, and hopefully with Hyp. Hellava guy, as I'm sure most of you know. So heres a couple more pics while its still in one piece, which I'm sure won't be long!
thats hawt jeff! I like how you got everything in the tvps.. Anything new since then?
Thanks Foo! Not much since. Got aluminum shock caps and spring retainers after breaking a cap after 15 seconds of the first run after the build! Also ate up a diff and upgraded to BP diffs. Other than that, still the same.
