Well, I can only share my experience with you
I found that all the XL stuff moved right over - the only difference is that the TVP's are a hair shorter, but they come with the correct length driveshaft - so other than the grunt work of moving everything over, you should find it to be quite complete... I personally like the TVp's with the servo mount holes in the side then you can relocate the servos VERY easily, and put whatever you want whereever you want pretty much...
On my first build, I made the mounts from scratch - not hard, just used aluminum angle iron. But getting everything to fit just right was a pain in the tail... This is the "before" pic:
And this is what it looks like now with the FLM mounts and TVP:
I suppose the argument could be made that buying is not as much fun as building, but it does take some of the frustration out of the process
Now, here is one of the beauties of the Savage - just about everything is the same just reused. For example, to make a tank mount, just use two motor mount cross braces and a sheet of aluminum. VERY easy. PM me if you need measurements.
I just converted from my custom build to the FLM TVP and I so far I like it, but I am sure that I will end up making something for it in the near future - I just don't know when to leave well enough alone
Bob
