Steering slop
TripleSix
U run nitro? I'm sorry.
Bartlett, IL
I just got my savy x a few days ago and after checking it out, there is quite a bit of play in the front end. Wondering if this is normal, and if not how to fix it. Thanks.
So there is nothing that can be done to fix the play? And how exactly do I shim the bearings?
I think he means put the correct size shims between the bearings and the pin that goes through the axle? I noticed i had a bit of play in that area... especically with the HD Extended axles....
Correct me if I'm wrong
