Bought a Axial .28 spec 1s
good luck with that mill.. its a good one for the money! and if you have only ran 3-gallons through your 4.6 its not toast unless you toasted it the last vid i posted had to be around gallon 10, and still running better than any HPI mill.. some people here don't understand its hard to come off $300.00 + MILLS (ALEX) lol. YOU MY BUD but 4 the price! i will buy another.. enjoy me showing a Flux how to get around a bashers track with the mill you just bough!!!
http://www.youtube.com/watch?v=oWD45gQ1Fb8
Thanks nitro!! I'm sure this mill will be good. and i've had alot more than 3 gallons on my 4.6, i just cant really remember lol. Also your truck looked like it was running good in the vid!!
Red Ducati nitro hehehehe.......
Tom hooked me up. two speed and all HEHEHEHEHE.......
Hey, i thought i heard a shot, was someone shooting at you guys or what?? LOL!!
I have said it before I'll say it again don't matter much what you run really cause these things always put a smile on your face.
Oh and we shall see if you still feel that way when Danny starts beating all you boys out there on the track. Lmao
Very true Alex!!! Got some new pics with the axial installed in the truck.
Yeah the Axial is a great motor. I have one and have ran probably close to two gallons of fuel through it and it only gets stronger. My only problem with it was a high idle problem, but once I sealed the engine, that went away. Also get a Nova RC cooling head for it, really helps bring out a little bit more.
had a little trouble today with the throttle return spring hitting the spur gear nut. no matter where i turned the carb i couldnt get WOT. i got to thinking and saw that some of you guys are using rubber bands for a return spring. a simple rubber band helped solve my problems LOL
Seen the thread before but haven't posted. I'm also runnin the same axial in my savvy (except it's modded) and I've got either close to 3 gals or almost 4
can't remember. Still runs strong and has tons of pinch still. Only problem I had was a leaking front bearing. Replaced them with some mid-grade boca's, and haven't had a problem since. Now I've got a leak some where around the carb, but haven't had time to investigate yet. Will be soon though. Just my 2 cents on the motor. I've been happy with it, but next is gonna be a ERCM picco.
