MikeK1981
ChondroManiac
- Location
- Humboldt, CA
OK I had taken my truck out for a good bashing and thought everything was all good afterwards. A few days later I went to show somebody how well the brakes worked and I rolled it across the floor. When I hit the brakes it didn't stop well and there was a grinding/clicking noise. I was like 'oh, that's not supposed to happen' LOL. I rolled it on the linoleum floor in the dining room and it looked like the rear wheels were braking normally but the front were still rolling when I braked and the noise was coming from the front diff area. I figured I must have blown the diff, but when I took it apart everything inside the diff looks fine, except one of the bearings by the outdrive was shot. It had actually come apart. If the bearing was locking up or causing friction, would that cause the symptoms with my braking/diff slipping??? I checked out the tranny, the grub screws on the cups to the main drivelines, and tried to turn the cup coming out of the front of the tranny with a screwdriver while applying the brakes and nothing slipped or made that noise. If that bearing wouldn't cause that, what else could? Anybody know which bearings I need for the diff outdrives? Also I need some clutch bell bearings? Can someone help me with part numbers and where I can get them cheap? Thanks in advance.
